Author Topic: Auto choke set backwards?  (Read 4787 times)
Offline Gambit
Re: Auto choke set backwards?
« Reply #20 on: 31 August 2004, 10:47 »
the CO% is not set correctly. needs set to 2% at idle with the engine breather on the airbox disconnected
that link details setting the CO%
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #21 on: 31 August 2004, 12:42 »
Yes I did check that, but first just to settle my curiousity I sliconed up around the idle screw (it was previously siliconed) and now it is running fine idles perfect, I must have disturbed the silicon that was previously on there, put on I guess as you mentioned about the rubber ring had probably worn.
Thanks again.
