Author Topic: Auto choke set backwards?  (Read 4700 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re: Auto choke set backwards?
« Reply #10 on: 26 August 2004, 12:44 »
Yep, the isv is buzzing
which spade is the ISV is it the top, left ot right one?
Also I forgot to mention (it may mean nothing) but when i start the engine from cold, the revs shoot up initially 2 around 2250 revs and then slowly come back down to around 960 revs
What is the oil temp reading when the revs are supposed to go to normal? I noticed that the revs were settling upwards from 80 C and 1200 revs at over 90 C (roughly)
Offline Gambit
« Reply #11 on: 26 August 2004, 13:49 »
you no probs with the ISV/Cold Start it all seems to be working perfectly - does exactly as your describing - just sounds like the idle is set a bit high
its probably worth setting the idle yourself. just warm the engine up to normal operating temp then disconnect the red wire at the coil, then turn the idle screw until it idles at 960rpm then reconnect the red wire.
if that dont fix it then look for airleaks, especially around the idle screw, the wee O-ring goes hard after a number of years and aint a tight fit
Offline Deefadog
« Reply #12 on: 26 August 2004, 14:38 »
I'll give it a go when I get home, one small question do i discontect the red coil wire when the engine is still running or turn engine off, disconect and then restart the engine?
Also the idle screw has already got some silicone around it from when i bought it so the seal may have gone! may have to get my silcone gun out :)
Thanks
Offline Gambit
« Reply #13 on: 26 August 2004, 17:26 »
yeah you can disconnect/connect it with the engine still running
im assuming your timing is correct also
« Last Edit: 26 August 2004, 17:30 by Gambit »
Offline Deefadog
« Reply #14 on: 26 August 2004, 17:37 »
Well I assume it is, had the timing belt changed si the timing must have been set, but my local garage does very good work as a good price but he aint to VW specialist! There is a VW specialist (old skool) does everything with a screw driver, and "how much is that then mate" ahhh call it a tenner :) but he did the timing on it last time so i may take it down there on the weekend to get it check
Thanks
Offline Deefadog
« Reply #15 on: 26 August 2004, 18:32 »
Ok, The top one is for the temp gauge, so I put it in to the other two and the temp gauge worked fine with them so senders are ok :)
Ran the car up to temp, unplugged the red lead and the idle screw took exactly one full turn (clockwise to get to 960 rpm)
Now all i got to do is let it get cold and start her up and see if the idle works when cold!
A few questions?
1) from cold what should the idle be (choke working)
2) at what oil temp does the idle resume to normal?
3) what does the red lead from the ISV do?
4) If from cold it revs very low and turning the idle screw back to where it was cures it, what could be the problem?
Thanks again for your help
« Last Edit: 26 August 2004, 18:46 by deefadog »
Offline Deefadog
« Reply #16 on: 27 August 2004, 08:04 »
Got to work all is good, idles as it should :) Thanks again gambit!
I would still like my few questions answered if you would not mind, just so i know for the future
Take care
Offline Gambit
« Reply #17 on: 27 August 2004, 10:00 »
on first startup, the car should start and fire up to approx 2k then drop gently down to about 1100-1200rpm, also the Warm Up Regulator will increase the fuelling for the 1st 7secs - call this your auto choke
havent a clue!, my general rule of thumb is never take it higher than 4k rpm till the oil temp is 88 degress
that tells the ECU what rpm the engine is at, so if you try and set the idle with it connected the ECU will constantly be fightin against you
its just not setup correctly!!
Offline Deefadog
« Reply #18 on: 27 August 2004, 10:30 »
Great! really helpfull!
Offline Deefadog
« Reply #19 on: 27 August 2004, 21:17 »
Car was running great so i treated it to a tank of Optimax :) Amazing felt much more nimble from the leaving the garge!
Only problem now (when warmed up) is that if I dip the clutch or put into neutral the idle drops to around 450-500, nearly cuts out and then recovers to 960 rpm, any ideas, i have noticed that when i press the accelerator I here a sight whistle noise like a faint turbo noise (I wish) Does this tell me I have an air leak somewhere and does this account or the revs dropping?
If so, what the best corse of action to find it, I can get hold of a can of gas leak detector that plumbers use, just deposits a thick solution via a spray head, this any good?
