Author Topic: vag com  (Read 1791 times)
Offline zeze89
  • 2000 1.8T AUM
vag com
« on: 03 July 2009, 14:34 »
hey all..
 im tryin to do a vag com run on my car but it keeps sayin
 "interface status=99, interface not ready!! possible reasons,
incorrect com port selected
interface not plugged in
k line stuck
firmware update needed...
ive installed it all corectly i think... i have the version on ebay ....
Offline topher
  • Administrator
  • fully functioning
Re: vag com
« Reply #1 on: 03 July 2009, 14:40 »
ignition on?
and which version of vagcom?
Offline Waffs1984
  • Spacers are for chumps...
Re: vag com
« Reply #2 on: 03 July 2009, 16:18 »
Have you gone into device manager and set up one of the posts to "COM1/2/3/4"? You need to do this!
I have the ebay shareware version of VAGCOM and have noticed that on my car (2001 AUM 1.8T) it will only read fault codes etc with the IGNITION OFF, if i have the ignition on it simply stops responding. BUT when i scanned a chap on heres TDi for him, it would only work with ignition ON. I'm assuming this has something to do with the older versions of vagcom and the different types of clocks?
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline zeze89
  • 2000 1.8T AUM
Re: vag com
« Reply #3 on: 03 July 2009, 19:39 »
i have the 409-1s version OBDII...
i have tried with ignition on and off...
when i go into the program options and select the COM port on
COM1,2 and 4 say "port does not exist" "interface not found"
COM 3 says
"port status: ok"
"interface: Found!"
"Type: serial pass-throught"
"Opto/Iso: NO"
"Ross-tech Design: NO"
Offline northeast_gti-t
  • "1.8T AGU"
Re: vag com
« Reply #4 on: 03 July 2009, 21:38 »
What operating system windows xp/vista? have a read of this and you will/should be sorted  :wink: http://www.golfgtiforum.co.uk/index.php?topic=119806.0
2000 Mkiv GTi 1.8T AGU
