Golf mk3
hardmonkeys
5000rpm limit ?
Topic: 5000rpm limit ? (Read 1243 times)
omex_uk
GTI forum regular
5000rpm limit ?
03 July 2009, 13:32 »
read up about this a bit. is it something to do with the timing belt being not on the right notch?
pretty much my rev limiters set at 5000.
any help would be appreciated lads
shepgti
Re: 5000rpm limit ?
03 July 2009, 13:33 »
correct, if its a notch out it will go into 'safe mode' get it re alined
omex_uk
GTI forum regular
Re: 5000rpm limit ?
03 July 2009, 13:39 »
sorted cheers mate
mrpatterson2008
Re: 5000rpm limit ?
03 July 2009, 19:30 »
Hi,, iv got the same problem ,, to fix it did you just adjust the distributor?? or is it the timing belt??
did you do it yourself or get a garage to sort it??
Len
10k hero
Re: 5000rpm limit ?
03 July 2009, 19:37 »
Its usually the timing belt mate! Just one notch out will do it.
www.sas.org.uk
www.the-ace.org.uk
VW Mel
GTI forum regular
Re: 5000rpm limit ?
03 July 2009, 19:38 »
90% because the timing belt is out
mrpatterson2008
Re: 5000rpm limit ?
Reply #6 on:
03 July 2009, 19:52 »
will the car run any different ?? or is it just limited to the 5000rpm???
Len
10k hero
Re: 5000rpm limit ?
Reply #7 on:
03 July 2009, 19:58 »
Well its not running to its optimum efficiency!
Thats why its limits revs to 5000. ECU goes into "safe" mode.
www.sas.org.uk
www.the-ace.org.uk
Mikester
Forum addict
Civic Type R
Re: 5000rpm limit ?
Reply #8 on:
03 July 2009, 20:02 »
It will be out only slightly. If it was to far out, more than a few teeth it wouldnt get compression.
It wont do damage at first, but would be advisable to get sorted out.
Golf mk3
hardmonkeys
5000rpm limit ?
