Golf mk1
rear dust shields(brake disc)
Topic: rear dust shields(brake disc) (Read 2038 times)
ian007miles
02 July 2009, 16:16 »
does any one no were i can get the dust shields that go behind the rear brake discs on a mk1 golf gti with disc converstion
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
garethmk1
GTI forum regular
Re: rear dust shields(brake disc)
02 July 2009, 16:45 »
No, if yours is a conversion, and if your mk1 has rear disks it will be, they wouldn't have made dust covers for a Mk1 because they were not original - try fitting Mk2 items. Why do you want these ? They reflect heat back onto the disk and pad ?
<br />Mk5 Golf GTi Edition 30 No:- 2101, 3Dr, Tornado Red, Rear Tints, RCD510 & Sound Pack, Arm Rest
Mk1 Golf GTi 16v, Helios Blue, Too Many Mods To List .....
ian007miles
02 July 2009, 16:53 »
all it was is that i took the brakes off the rear axle to get it powder coated(the axle) and the dust shields were nackered so i wanted another set to but back on and i dont real drive the car enough for the rear brakes to get that hot just to shows and things and it the mk2 items i trying to get
Wayne
Sir Postalot
02 July 2009, 23:50 »
You need mk2 ones.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
06 July 2009, 08:58 »
Depends on what calipers you have, the part number changed from 87-88 on the MK2. The early MK2 part number is the same as the scirocco 16v shields, then the later MK2 ones had a different part number.
Golf mk1
