Author Topic: How many people spaced out here?  (Read 1781 times)
Offline Car nut
  • The Black Beaver
« on: 02 July 2009, 10:49 »
Of course!!
I'm referring to having spacers on your wheels!!
Fors and against ?
« Last Edit: 02 July 2009, 10:59 by Car nut »
Daily Hack - '53 - AUM - GTI T  "The Black Beaver" :wink:
Playing with a  Black Beaver   :grin:  -  Updated  -  Wed, Jul 8 2009 4:56 PM
BMW E39 M5 Individual '02- 400bhp - Sold but not forgotten !
Jaguar E Type S1 FHC 3.8 - Project car on my website in Profile
Offline Waffs1984
  • Spacers are for chumps...
Re: How many people spaced out here?
« Reply #1 on: 02 July 2009, 11:33 »
Against... "spacers are for chumps"...
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline Adam
« Reply #2 on: 02 July 2009, 13:13 »
Unsafe
Down Hill From Here.
Offline james2
  • No scammers please.
« Reply #3 on: 02 July 2009, 16:35 »
 :cool:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #4 on: 02 July 2009, 16:45 »
Unsafe
not if they are of the hubcentric fitting as these are bolted to the hub and have a locating collar to fit inside the hub lip i'm running 15mm hubcentric spacers on the rear and have no problem what so ever  :wink:
2000 Mkiv GTi 1.8T AGU
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 02 July 2009, 16:50 »
yep ^
As long as they're hubcentric you should have no problems. Adaptors to change the PCD are a different matter because they have to use stubby countersunk bolts to the hub.
Just remember to get longer wheel bolts if you're spacing more than 5mm.
Offline gjroe78
« Reply #6 on: 02 July 2009, 17:07 »
Unsafe
yep ^
+1 :wink:
Offline Steve_PD
« Reply #7 on: 02 July 2009, 17:33 »
yep ^
Get new bolts anyway, I had 5mm spacers fitted with standard bolts and they only went in 4 turns and caused wheel wobble. got new bolts now turn in 9 turns and no wobble  :smiley:
Offline linz
  • vee-dub
« Reply #8 on: 03 July 2009, 08:37 »
i have spacers an le it :)
Offline Grand Master Patch
« Reply #9 on: 03 July 2009, 09:21 »
yep ^
Yes you should always take the thickness of the spacer and add that to the length of the bolt,std VW wheel bolt has a 28mm thread so 5mm spacer requires at least a 33mm thread.
I run 5mm up front and 20mm on the rear,hoping to lose them soon if i can get my custom wheels made to suit :lipsrsealed:
