Author Topic: When replacing suspension bushes....  (Read 920 times)
Offline Mikester
  • Civic Type R
« on: 01 July 2009, 16:32 »
Im going to get the following suspension powerflex bushes, to have fitted when i have my new coilovers put on.
Just wondering if there is anything that is cheap and easy to get replaced at the same time, that is worth it.
Going to get powerflex front and back wish bone bushes.
Rear beam bushes.
Front subframe mounts.
Was going to get the anti roll bar bushes as well, but unless its worth uprated ones might just replace them with oem ones to keep the cost down. But want to get the suspension as good as possible. Probably going to go for FK coilovers this time, might go up to entry level weitecs, but not sure.
So yeah, anything i should replace at the same time? Im not to clued up on suspension. So what joints, bearings or metal should be replaced at the same time as those bushes?
Offline LazyLunatic
  • MK3 20VT Project
Re: When replacing suspension bushes....
« Reply #1 on: 01 July 2009, 17:11 »
might as well do the whole lot with powerflex, expensive, but still worth it.
i dont know if its just me, but are the front subframe bushes impossible to replace!?!?
other stuff you can replace - hub ball joints, track rod ends.....
