Author Topic: Angel Eyes  (Read 3669 times)
Judderi
Angel Eyes
« on: 23 August 2004, 14:55 »
Does anyone know where i can get a set of clear angel eye lamps from?
Offline davidhawkins_78
  • Valver Bad Boy
Re: Angel Eyes
« Reply #1 on: 23 August 2004, 15:24 »
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline phillyh
Re: Angel Eyes
« Reply #2 on: 23 August 2004, 17:43 »
whilst were on the subject, i was wondering whether its possible to fit angel eyes to my jetta front end.
i know they dont make the kit. but those univeral jobbies might do the trick, only problem then is getting clear lenses. does anyone know where if there made??
i've not seen it done before
« Last Edit: 23 August 2004, 17:45 by phillyh »
Fielder5757
Re: Angel Eyes
« Reply #3 on: 24 August 2004, 12:29 »
I was wondering the same thing, I know they do em for the Mk3 tho, So im thinking about doing a Mk3 headlamp conversion  ;)
Offline jv
  • Administrator
Re: Angel Eyes
« Reply #4 on: 24 August 2004, 12:40 »
on a mk2 fielder? would have to go some to make that look good!
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Fielder5757
Re: Angel Eyes
« Reply #5 on: 24 August 2004, 12:50 »
Hmmm fitting the lights would be easy, Just drilling some holes into a Mk2 Jetta slam pannel to mount them, It would be constructing a surround and grill that would be the hard part. I guess you could use an existing Mk2 grill and place that between the lamps, Mounted on the slam pannel, But you would have huge gaps between all the pannels and the lights that would need to be filled by some sorta custom fabricated pannel to plug the gaps? :-\ Could prove pricy. however if you look at the Mk3s front end, The lights look almost identical to the jetta lamps on the outside, on the inside towards the grill they vairy in shape. You could get away with the tops of the lamps by hiding them using a Jetta grill spoiler and you could probally cut the two small parts off the Mk3 lower grill spoiler to fit under the lights, Then make them join to a Mk2 grill and you would have the grill 99% done, All you would need to do after that would be to cut some metal to wrap around the inside parts of the lights and to match up with the Mk3 grill. Using the existing grill from a Mk3 wouldnt work because of the size difference.
« Last Edit: 24 August 2004, 12:55 by Fielder »
Offline phillyh
Re: Angel Eyes
« Reply #6 on: 24 August 2004, 12:56 »
mk3 jetta lamps would look mingin on a mk2
i think, different but mingin.
i think im just gonna get some of those ?10 angel eye kits and see how it looks. if it looks pants without nice clear lenses, ill sell them on.
Fielder5757
Re: Angel Eyes
« Reply #7 on: 24 August 2004, 14:07 »
On that note, Check this out, Bora lights on a Mk2!
Offline 16v Matt
Re: Angel Eyes
« Reply #8 on: 24 August 2004, 14:34 »
LOL, they don't fit!!
Offline dubslug
Re: Angel Eyes
« Reply #9 on: 24 August 2004, 16:15 »
that special aint for angel eyes is it??
1992 pearl grey 8v
