Author Topic: Piston Rings (white smoke)  (Read 9228 times)
Offline bondbill2k2
« on: 30 June 2009, 22:57 »
Ive noticed my mk4 has been leaving clouds of white smoke sometimes, not all the time. Only had it happen when warm
When does it happen? Well thats the problem, random, not had it when ive put my  foot down, had it when downshifting (on a hill, not using engine braking)
and when just changing a gear before or accelrating abit.
My mate also noticed/heared a sound when it happened last, sounded much like the exhaust so its got me thinking something to do with the box or cat?
 :cry:
« Last Edit: 02 July 2009, 10:53 by bondbill2k2 »
Offline richw911
Re: White smoke from exhaust
« Reply #1 on: 30 June 2009, 23:51 »
Could be a number of things which engine do you have?
Could be head gasket or a valve  :undecided:
Offline bondbill2k2
« Reply #2 on: 30 June 2009, 23:55 »
Its a 1.4. Worst fears are something expensive  :undecided:
Could explain why previous owner was selling it.
Offline richw911
« Reply #3 on: 30 June 2009, 23:58 »
I would say head gasket - get the head pressure tested IMO.
http://www.benplace.com/pressure_test.htm
Offline bondbill2k2
« Reply #4 on: 01 July 2009, 00:06 »
It only does it rarely, my dad followed me back from collecting it (80mile trip) and did it once or twice whole journey.
Still worth checking out?
Offline richw911
« Reply #5 on: 01 July 2009, 00:08 »
Yeah for sure good garage wont charge a lot - also have a look to see if you coolant is going down  :smiley:
Offline james2
  • No scammers please.
« Reply #6 on: 01 July 2009, 08:29 »
head gasket :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline bondbill2k2
« Reply #7 on: 01 July 2009, 09:14 »
bet that wil be costing me my arm and a leg.
Going to call and take it to Vw rescue get them to do VAG diagnostics and a check over, get to bottom of it and find if anything else needs doing.
http://www.vwrescue.co.uk/index.php
Offline AlanD
  • MK5 2.0T 16v
« Reply #8 on: 01 July 2009, 09:54 »
If it is the headgasket it wont be cheap.
But lets not jump to conclusions just yet.
Offline linz
  • vee-dub
« Reply #9 on: 01 July 2009, 10:18 »
could also be down to coilpacks
