Golf mk1
Cab Hydraulic Hood
Topic: Cab Hydraulic Hood (Read 1303 times)
JonMk1Cab
Cab Hydraulic Hood
23 August 2004, 13:02 »
Finally found the leak to the hydraulics in the hood, the reservoir has a hairline crack on the underside (the plastic bit at the bottom of the pump). Replacement from VW is the whole unit at over ?1000. Does anyone know whether it is possible to replace separately? Looks like the plastic weld/silicone sealant will have to have a go. Hope I don't catch "pneumonoultramicroscopicsilicovolcanoconiosis"
Jon
AdamB
The Perfect Storm
Re: Cab Hydraulic Hood
23 August 2004, 13:07 »
It may be worth trying to source one second hand, from a breaker. I think your idea of silicone sealant is worth a shot, but the pressure may be to much for it. I can not see any reason why the fluid reservoir cant be replaced seperatly.
I don't own this anymore - I just can't be arsed to change the picture
JonMk1Cab
03 September 2004, 13:43 »
Managed to get it fixed by my mate that works in a Body Shop. Plastic welded the crack - looks ugly with a black plastic line, but does the job.
Using it every day at present trying to give it a few good blasts to clean away the cobwebs.
Jon
Golf mk1
Cab Hydraulic Hood
