Golf mk5
Lumpy idle.
Topic: Lumpy idle. (Read 2834 times)
Pintman
Re: Lumpy idle.
Reply #10 on:
30 June 2009, 20:01 »
FYI
The p/n and description on the invoice sent off to Tesco was:
06F 129 101L Valve
06F 103 483E Gasket
Fault was noted as the recirculating valve in manifold.
sambo
Re: Lumpy idle.
Reply #11 on:
01 July 2009, 17:56 »
Ordered the TSi DV and an air filter today, £48.50 inc vat.
Should be here tomorrow, will let you know how I get on!
Cheers, Sam
Sam
AXX power! .. Tinkering has started....
M11BYH
Re: Lumpy idle.
Reply #12 on:
01 July 2009, 19:32 »
You should try removing you air mass meter then go for a 2minute test drive. see if the idling has gone or is still there. if it has gone this means you mass air flow sensor has burnd out. i had you symptoms too and this fixed it. although try the others methods first as this is more expensive.
Golf mk5
Lumpy idle.
