Author Topic: electric window fix??  (Read 864 times)
Offline axewielder
  • 95 dragon 8v
« on: 30 June 2009, 13:15 »
my rear electrice window is broke, motors fine, will go down but not up, i presume it has detatched itself from the cable that pulls it up. Does anyone have a link to a diy or any useful info. I have searched but not come up with much.
Any help muchly appreciated
Cheers Joe
Offline JamesBaby
Re: electric window fix??
« Reply #1 on: 02 July 2009, 09:04 »
Hi Mate
I just replaced the motor and regulator on the rear window. Cost me £15 from the breakers (haggled him from £25) for the whole thing. Very easy to replace yourself. Lower the window so you can get to the two bolts holding the glass and undo them just enough so you can lift the glass off the clamp. Tape the window in place or get mate to hold it. Then remove the 3 bolts holding the assembly into the door, and slide off the power cable clamp. Refitting is the reversal of removal. :smiley:
You can replace the whole thing like I did or just the regulator if you can be bothered removing all the screws from the motor.
Offline axewielder
  • 95 dragon 8v
« Reply #2 on: 02 July 2009, 10:21 »
Cheers man very useful info
Offline knocker
« Reply #3 on: 07 July 2009, 19:11 »
Or brand new for £45.62 + vat
Offline axewielder
  • 95 dragon 8v
« Reply #4 on: 09 July 2009, 14:06 »
brand new??, thats just not how i roll
ill fix it somehow!!
