Author Topic: New head gasket - oil leaks?  (Read 3361 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 23 August 2004, 10:19 »
I have just had  new valve stem seals fitted to my 16V andnow since the head has come off, there is an oil leak, I think it is coming from the large pepe just left of the main breather hose!  What is this pipe and should oil be able to leak from here?
Thanks
Offline 16v Matt
Re: New head gasket - oil leaks?
« Reply #1 on: 23 August 2004, 10:54 »
Dude, if that were me i'd her take back right NOW.
Offline Deefadog
« Reply #2 on: 23 August 2004, 11:05 »
If it's just a matter of tighneing up a clip, I'll do it my self, just want to know what this pipe is, head seems fine, no sign of leaks there, but if I can't get it sorted it will go straight back :)
Offline 16v Matt
« Reply #3 on: 23 August 2004, 15:23 »
You got a pic mate?
Offline Deefadog
« Reply #4 on: 23 August 2004, 16:00 »
I'll take one ASAP when I get home from work!
cheers
Offline 16v Matt
« Reply #5 on: 23 August 2004, 16:05 »
Cool & the gang ;)
Offline Gambit
« Reply #6 on: 23 August 2004, 16:40 »
the large pipe to the left of the main breather is a water pipe, so u cant have oil leakin from that
Offline Deefadog
« Reply #7 on: 23 August 2004, 21:14 »
*Feels so embarrsed* :) Yep Gambit was right, figured this out earlier when I took a better look, been raining hard down here lately.
It just a clip round the water pipe, it's rusty/browny water that was dripping, not oil i don't think! Must have got disturbed when the head came off!
The clip is the one that you need four pairs of hands and three mole grips to get off! can I just replace this with a jubilee clip?
Offline Gambit
« Reply #8 on: 24 August 2004, 09:19 »
yeah you can just stick a jubilee clip on it. mine has one on it
and if its pumpin out brown rusty water id be looking to flush the system out completly to get rid of all the gunk. then refill with nice new antifreeze/water mix
Offline Deefadog
« Reply #9 on: 24 August 2004, 12:42 »
Good point, I'll get it flushed and add new coolent for the coming winter :)
What's the best point to drain the system, any advice or dhould I just follow the Haynes manual, also what's the best coolent to get?
Thanks
