Author Topic: 16v Induction kit  (Read 2160 times)
Judderi
16v Induction kit
« on: 23 August 2004, 09:27 »
Hi. Sorry if this is a common question but ive just got my hands on a 16v mk2 and would like to put an induction kit on it. But it doesent look that simple. Whats the thing with the pipes that sits on top of the air box? Do i take the airbox out? Where abouts on the intake pipe should i fit a filter. Pics would really help.
Cheers.
Offline Dizzie
  • Make friends with your fast
Re: 16v Induction kit
« Reply #1 on: 23 August 2004, 13:17 »
you can't fit one.
the pipes on the top are part of the injection system. if you know how the k-jet works you'll understand. the best you can hope for is to fit a replacement filter and drill the airbox.
Judderi
« Reply #2 on: 23 August 2004, 14:44 »
Aready got a replacement kn pannel filter. Guess its time to attack the air box! Just out of curiosity can you briefly tell me how the k jet injection works?
Offline Gambit
« Reply #3 on: 23 August 2004, 16:55 »
PiperX make an induction kit for the 8v/16v k-jets, your existing airbox top just clips on to it
its a waste of money though, you'll get a better noise out of an air box with the resonater tube removed
Offline Helios_Blue_Valver
« Reply #4 on: 25 August 2004, 08:09 »
I saw one advertised at cult society that uses an adaptor plate on the bottom of the air box top into a cone filter. looks pretty trick but i bet it plays h3ll with the air flow meter. Just drill out your airbox plunk in a K&N and go from there. If you have an 89 or under car might want to change to a 90 and up airbox as they are bigger and use a larger filter. I have been thinking of buying a power rohr lately. doesn't do fook all probably but looks good under the bonnet. lol.
Judderi
« Reply #5 on: 25 August 2004, 10:18 »
Yeah but shiny is good! I think i must have been a magpie in another life cos i just cant resist! P.S What is this resonator? Is it the bit that sticks out of the side of the bottom of the box?
Offline tobz.
« Reply #6 on: 25 August 2004, 11:32 »
Check out this site:
http://www.auto-solve.com/mech_inj.htm
It's got everything there you need in order to have a basic understanding of the k-jetronic system.
Toby
You got any pics of your dad's split ?
Offline Dizzie
« Reply #7 on: 25 August 2004, 15:28 »
breifly: when you put your foot down you open the throttle body. air flows into the engine and at the same time a plate lifts. the higher the plate lifts the more fuel is pumped into the cylinder.
