Author Topic: NEED HELP!! car pulling to right  (Read 1201 times)
Offline spider200
« on: 29 June 2009, 23:52 »
hi all
i recently took all my wheels off my gti, 1 at a time too clean them they went back on in the exact same position they came off, but since putting it back together it veers to the right with alot of steering wheel wobble. i have had the tracking done with no effect so i changed the lower arms and ball joints still with no effect i need help has anyone got an idea of what caused this problem what it is and what i can do to repair it thanks all.
Re: NEED HELP!! car pulling to right
« Reply #1 on: 30 June 2009, 00:05 »
Could be a camber issue.
jamie16v
« Reply #2 on: 30 June 2009, 00:06 »
hmm.. not bumped it at all either?.. what are your tyres like tread, pressure ect?.
Offline spider200
« Reply #3 on: 30 June 2009, 00:14 »
not bumped it at all it happened soon as put wheels back on the car all tyres are of good conition and pressure is 30psi in all. im baffled????
Offline Ben_1uk
« Reply #4 on: 30 June 2009, 07:34 »
Have you lost a wheel weight? One of the wheels might be out of balance.
Powered by the fuel of satan!
Offline james2
  • No scammers please.
« Reply #5 on: 30 June 2009, 11:53 »
strange.. you didnt do any damage when you jacked it up did you   :shocked:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
jamie16v
« Reply #6 on: 30 June 2009, 11:59 »
i was just thinking that myself..
where did he jack it up to?..
Offline rheady
« Reply #7 on: 30 June 2009, 13:31 »
Have you checked to face of the alloy, is there anything stuck there. Is it pulling to the right when driving or when breaking??
