Author Topic: problem when breaking on gt tdi  (Read 2464 times)
Offline GJSEB79
« on: 29 June 2009, 21:07 »
hi there when i break on golf gt tdi ie coming up to a juction the is a juddering noise and the engine sounds like it is going to stall also my abs light is on what could this be cheers gordon all it feel like there is some flat spots through the rev range never had a tdi before can some one help me please
Offline christianduncan
Re: problem when breaking on gt tdi
« Reply #1 on: 30 June 2009, 00:27 »
hi mate
have you tried you air mass meter? this can cause turbo problems and tick-over problems.  it can also cause your engine to lack in power????
Offline Rhyso
« Reply #2 on: 30 June 2009, 07:52 »
sounds like you've got problems with your ABS system
the juddering could be warped discs and pads - get them checked out ASAP!
« Reply #3 on: 30 June 2009, 10:38 »
yes that sounds correct it could also be your tracking and your wheel balancing if its juddering when braking because mine did this ;-)
Offline GJSEB79
« Reply #4 on: 30 June 2009, 13:29 »
hi there if feels fine then though when you beaking at high speeds it just when pulling up to junctions an that its werid to explain its like the car is about to stall when you put your foot on the breaks but it doesnt stall its doing my head as the car drives spot on apart from that cheers gordon
