Author Topic: Failed MOT...  (Read 1441 times)
Offline gtiscott
Failed MOT...
« on: 29 June 2009, 15:35 »
car just failed its mot on...
Reason(s) for refusal to issue Certificate
Nearside Registration plate lamp not working (1.1.5c)
Nearside Front Macpherson strut has excessive movement at the upper attachment (2.5.A.1c)
Offside Front Macpherson strut has excessive movement at the upper attachment (2.5.A.1c)
Offside Rear Shock absorber has a serious fluid leak (2.7.3)
Anti-lock braking system warning lamp indicates an ABS fault (3.4.1d)
Nearside Rear Brake disc(s) excessively pitted (3.5.1h
really gutted as this is going to be costly
scott
Offline Adam
Re: Failed MOT...
« Reply #1 on: 29 June 2009, 15:47 »
Coilovers- £170 cheap
Top mounts - £20
ABS sensor - £15
Disk - £30
501 light - 0.69p
Meah......
Down Hill From Here.
Re: Failed MOT...
« Reply #2 on: 29 June 2009, 16:04 »
Not going to be that expensive to fix, fit a pair of rear discs however.
Offline Len
Re: Failed MOT...
« Reply #3 on: 29 June 2009, 16:29 »
And when changing rear discs you also have to change the wheel bearimgs!
Another thing to look out for is the ABS ring. You can take them off and push into new discs but if you dont feel confidant then I believe you can get the new discs with the ABS ring fitted.
www.sas.org.uk
www.the-ace.org.uk
Offline gtiscott
Re: Failed MOT...
« Reply #4 on: 29 June 2009, 19:41 »
thanks for the replys guys, not going to do the work myself, not good enough to mess with brakes :laugh:.
scott
Offline Mikester
  • Civic Type R
Re: Failed MOT...
« Reply #5 on: 29 June 2009, 21:42 »
My new rear discs came with rings fitted, and it looked pretty impossible to remove the old ones, without some serious popeye action going on. lol.
Offline bored_Welsh_lad
Re: Failed MOT...
« Reply #6 on: 29 June 2009, 22:35 »
they come off easy mike.. a small screwdriver and a hammer n tap all the way around!!
use plenty of wd40 too
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
