Author Topic: The dreaded humming noise  (Read 1802 times)
Offline SW VR6
« on: 22 August 2004, 23:47 »
My 97 VR6 with 87k on the clock has just starting making a humming noise at certain road speeds.? Sounds very similar to the noise you would expect from a worn wheel bearing, but I had the car checked over a month ago and there was no play on any of the wheels.? I've also checked them again myself tonight and I can't feel any movement.? Could it be anything else?
I seem to remember reading somewhere that when the rear tyres are worn right down on the Mk 3 you can sometimes hear a similar noise.? My rears are down to the markers and are due for replacement next week.
Anybody got any idea how much a wheel bearing replacement would be at a decent independant garage?
My mate's Alfa GTV makes this noise all the time, but that's a known problem due to a quirk with the rear suspension.
Offline vanish
Re: The dreaded humming noise
« Reply #1 on: 24 August 2004, 05:13 »
I had the same probs a few months back. Had the humming noise but no play in the wheels. Took it to local garage and they checked it out properly and the off-side bearing had gone. Cost? ?22 for each new bearing set (I replaced both front sets while I was at it) and a couple of hours labour, came to just over ?100. If you only replace the one then that cost would be halfed, obviously!
Hope this helps.
What better time than now, what better place than here?
