Author Topic: Safe mode  (Read 1297 times)
Offline Dj Don
Safe mode
« on: 28 June 2009, 18:13 »
After reading a couple of posts i believe my car is in safe mode and only revving to 5000rpm . It has always done this while i have owned the car and i just thought it was the limiter , Could anyone tell me what may of caused this to happen and how i would go about sorting it .  :huh:
Offline Mikester
  • Civic Type R
Re: Safe mode
« Reply #1 on: 28 June 2009, 18:24 »
It is because the timing is out, basically the cambelt hasnt been put on properly. Take it to a garage asap, as its not good. But if its been like that for a while, it will be fine. But just get the timing checked and done properly, but a propper garage, not a cowboy.
Offline Dj Don
Re: Safe mode
« Reply #2 on: 28 June 2009, 21:05 »
would the engine management take it out of safe mode automaticaly once the timing is sorted or will it need taking of safe mode manually .
Offline Mikester
  • Civic Type R
Re: Safe mode
« Reply #3 on: 28 June 2009, 21:10 »
Automatically.
Offline Dj Don
Re: Safe mode
« Reply #4 on: 28 June 2009, 21:14 »
probably worth getting a new cam belt on then ?
Offline Mikester
  • Civic Type R
Re: Safe mode
« Reply #5 on: 28 June 2009, 21:16 »
Definetly. Cambelts are not that expensive. So might as well just stick a new belt on it at the same time. Wouldnt hurt.
Offline Dj Don
Re: Safe mode
« Reply #6 on: 28 June 2009, 21:32 »
Thanks for a quick reply mate  :wink:
