Author Topic: Is this Normal?  (Read 3843 times)
Offline ub7rm
Re: Is this Normal?
« Reply #10 on: 27 June 2009, 19:16 »
Mine is an 05 GTI engine code AXX and have the very same hole.  Did ask VW along time ago and they said it was ment to be like that.
Thats reassuring - but a bit odd at the same time.  Thanks for that.  :smiley:
2020 BMW 128ti
2017 Golf GTD Estate
Offline CHRIS-M07GTI
Re: Is this Normal?
« Reply #11 on: 29 June 2009, 22:07 »
It looks like the view hole for the mechanic to get Top dead centre if needs be,the ring/cog is the starter ring, the starter motor connects to this and turns the engine over.
One of the teeth will have a red mark on it.
Should have a little rubber plug though.
Chris.
neo66
Re: Is this Normal?
« Reply #12 on: 29 June 2009, 22:38 »
^What he said. Timing mark quite possibly. (tho if it was a Saxo which it isn't- TDC sensor)
Offline SoundillusioN
Re: Is this Normal?
« Reply #13 on: 29 June 2009, 23:03 »
What they said  :grin: I have seen that on other cars, i havent got my 5 anymore or i'd have a look.  I'm more confused about the cars on here where its totally flush??
Offline Teutonic_Tamer
Re: Is this Normal?
« Reply #14 on: 30 June 2009, 04:06 »
While sticking my head under the bonnet today I noticed this 'hole' in the top of the (I'm assuming) gearbox.  You can actually see (what again I'm taking a stab at is) the flywheel or some other damn big cog.  Do other (manual) GTI's have this open or is there supposed to be some sort of plug over it?
You can see it looking in from the battery side down towards the engine / gearbox area.
I would be obliged if someone could maybe check?
That is fine and dandy.  Just an inspection hole for starter ring gear on the flywheel.
I feel like a homo
Offline ub7rm
Re: Is this Normal?
« Reply #15 on: 30 June 2009, 08:15 »
Its good to hear that from the oracle.  Welcome back T_T  :smiley:
2020 BMW 128ti
Offline AlanD
  • MK5 2.0T 16v
Re: Is this Normal?
« Reply #16 on: 30 June 2009, 09:31 »
Call off the search party ! We found him :D
Offline bobotheclown
Re: Is this Normal?
« Reply #17 on: 30 June 2009, 12:36 »
Yay, welcome back T_T!!!!
Offline sambo
Re: Is this Normal?
« Reply #18 on: 30 June 2009, 18:48 »
Mine's got a little rubber bung with a bit that sticks out the top so you can remove easily in that hole!!
HTH Sam  :smiley:
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline ub7rm
Re: Is this Normal?
« Reply #19 on: 30 June 2009, 19:04 »
HTH Sam  :smiley:
Thanks!  I thought it was a bit odd that it was just open like that.  I'll make sure its replaced on Friday.
2020 BMW 128ti
