Author Topic: Replacing an engine ECU advice  (Read 3710 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: Replacing an engine ECU advice
« Reply #20 on: 29 June 2009, 19:15 »
Quote
whats the bsi unit?
The BSI unit controls a number of basic functions including indicators, ignition lights on with the key, cluster readings and also aids in starting the engine by talking to the ECU to engage/disengage the immobiliser :nerd:.
ah right when i did the engine conversion i had to send the clocks ecu and key off to be matched together for the immob, didnt know about a bsi unit or is it inside the clocks?
Offline Ben_1uk
« Reply #21 on: 29 June 2009, 20:07 »
Quote
Nah mate, it's an actual chip like the ECU.
Powered by the fuel of satan!
Offline xpeterpx
« Reply #22 on: 30 June 2009, 12:03 »
Is it worth asking the guys at R-Tech for the definitive answer on this even though its not a remap?
Offline Ben_1uk
« Reply #23 on: 30 June 2009, 12:06 »
Possibly if your convinced its ECU related...
Offline Rhyso
« Reply #24 on: 30 June 2009, 12:09 »
always worth a phone call mate
whereabouts in the country are you??
Offline xpeterpx
« Reply #25 on: 30 June 2009, 12:21 »
East Hertfordshire
Offline Rhyso
« Reply #26 on: 30 June 2009, 12:30 »
maybe a bit far - they're in Hinckley, Leceistershire - approx 90 miles from you or so depending on your exact location
give them a ring and see what they say  :smiley:
Offline xpeterpx
« Reply #27 on: 30 June 2009, 12:42 »
Cheers guys and can I just say that I appreciate all the advice given
Pete
