Author Topic: Replacing an engine ECU advice  (Read 3705 times)
Offline xpeterpx
Re: Replacing an engine ECU advice
« Reply #10 on: 29 June 2009, 14:21 »
I've been trying so solve the unsolvable and have exhausted all other possiblilites on my lumpy idling problem(-see my earlier post).I know it a long shot and extreme but I'm fortunate enough to have had a spare one offered by a mate whos breaking his mk4 so just thought it might be a simple plug and play/recode operation as I have full vagcom access.
Offline Ben_1uk
« Reply #11 on: 29 June 2009, 14:24 »
Quote
I wouldn't have thought this would solve the problem. Have you tried the usual?
- split leads/hoses
- coil pack
- spark plugs
Have you scanned it to see if it chucks out any fault codes???
Powered by the fuel of satan!
Offline xpeterpx
« Reply #12 on: 29 June 2009, 14:30 »
Yes mate went over the breather pipes at the weekend and couldn't spot anything sinister.Also changed the fuel filter to eliminate that too..
http://www.golfgtiforum.co.uk/index.php?topic=121046.0
Scanned many times with the full registered version of vagcom and comes up clear every time!
Offline Rhyso
« Reply #13 on: 29 June 2009, 14:31 »
i'd be very surprised if it was an ECU problem - you don't tend to hear of them going wrong  :undecided:
is it not something like a gasket or seal perished??
Offline xpeterpx
« Reply #14 on: 29 June 2009, 14:46 »
Possibly,but where would I start with checking? Are there any 'notorious' ones on the mk4 I could start with?
Offline Ben_1uk
« Reply #15 on: 29 June 2009, 14:51 »
I can't remember the name of the valve (think it might be EGR), but that can sometimes get clogged up with crap and cause performance problems???
Offline Rhyso
« Reply #16 on: 29 June 2009, 14:57 »
inlet and exhaust manifold gaskets maybe??
i believe they are fitted to diesels only mate
Offline Ben_1uk
« Reply #17 on: 29 June 2009, 14:58 »
Just read the original thread - it was the TB I was on about :embarassed: and yes, it's been cleaned already!
Offline dai-cymru
  • 1989 MK2 16V
« Reply #18 on: 29 June 2009, 16:49 »
whats the bsi unit?
Offline Ben_1uk
« Reply #19 on: 29 June 2009, 19:12 »
Quote
whats the bsi unit?
The BSI unit controls a number of basic functions including indicators, ignition lights on with the key, cluster readings and also aids in starting the engine by talking to the ECU to engage/disengage the immobiliser :nerd:.
