Golf mk2
Quick brake bleeding question
Topic: Quick brake bleeding question (Read 1928 times)
maxp
J reg 8v digi gti
27 June 2009, 00:50 »
When bleeding the brakes on my mk2 gti do i have to have the compensator valve open when bleeding just the rears or for the front brakes aswell?
Lap
GTI forum regular
Re: Quick brake bleeding question
27 June 2009, 09:28 »
You only need it for the rears.
Diamond Hell
Serious forum addict
Opinions я Us
27 June 2009, 11:17 »
If you're bleeding the brakes you should really do all four corners. New fluid all round will help keep your braking system up to spec - no harm in pushing it through the whole system.
maxp
J reg 8v digi gti
27 June 2009, 11:29 »
I meant when doing the fronts did the compensator valve need to be open.
I suspect not, but dont really wanna get it wrong.
Diamond Hell
Opinions я Us
27 June 2009, 22:57 »
The brakes are dual circuit, diagonally split. As such, both halves of the circuit have a T in them where the pipe goes to the back of the car. As such I would recommend you open the compensator at all times when bleeding the system.
Horney
10k hero
Racing, Trackdays, Starwars.
23 August 2009, 09:41 »
Need to bleed my rears today. How do I open the compensator? Mine is disconnected from the beam if that makes any difference. I don't have a Golf haynes at the moment!
Nick
Diamond Hell
Opinions я Us
Reply #6 on:
23 August 2009, 16:31 »
Quote from: Horney on 23 August 2009, 09:41
WTF?
I guess you're not going to be carrying any loads around, to be fair.
I guess you'll just need to trap it open in the 'other' position to which it is in at the moment, provided it still moves.
Horney
10k hero
Reply #7 on:
23 August 2009, 18:04 »
It's a bit stuck but managed to bleed em fine with the engine running.
Nick
johnson6672
Reply #8 on:
23 August 2009, 20:47 »
Is there a info section for this?
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
peaky83
Here all the time
Reply #9 on:
29 April 2010, 16:54 »
Sorr to drag up an old post, how do i distinguish between the valve being open and closed?
Golf mk2
