Author Topic: revs up and down slightly and not as responsive as should be???  (Read 2423 times)
Offline chol_gti
okay so i cleaned throttle body 2day and a few surrounding pipeswasnt overly dirty but still.
went for a drive i thought it felt better then came bk whacked it on diagnostic and cums up with
throttle sensor position closed
random misfire
misfire in cylinder #3
so i take it me cars fooked :( all i need when after being made redundant and theres no jobs out there not happy at mo.
Offline bondbill2k2
wow someones overdramatic a misfire can be from a number of things!
Offline chol_gti
its just because its 1thing after another atm and its stressing me out because ive had the car around 4months when i got it, it wasnt running amazing but i thought this was due 2 the maf which it was then the lambda sensor and a few other faults etc
anyways can any1 help me out on here with the what it could be? thanx
Offline Rhyso
I think the sensor is approx £30 and VW will know it as a CAM Position sensor
Topher or ivor will know for sure  :nerd:
Offline chol_gti
u think this is the reason i have a misfire in cylinder 3 also or just the throttle sensor?? cheers
Offline Rhyso
my guess would be the throttle position sensor IS causing the misfire
either way you need to replace the sensor
Offline chol_gti
cant understand it looks brand new! theres noway i could of put the throttle body or pipes back together wrong is there thats causing the misfire??
i had the throttle position sensor closed b4 i did it , but with these 2 new 1's comeing up after is it something ive done?
would throttle position being closed affect my car alot?
thanx for help really appreciate it.
Offline chol_gti
plz? might go vw and get one how much u reckon?
Offline chol_gti
okay so ive been vw 2day and the part isnt called the throttle sensor as said and they cant find a part called CAM position sensor. so im a bit confused on which part i need and so was the bloke, he came back to me with another sensor which cant remember name which was gona cost £90 but i didnt know if it was the correct one.
can some1 help me out and tell me which sensor i need please???
again prob is ''throttle position sensor - closed'' thats what the code reads.
thanx
Offline chol_gti
any1 please would like 2 fix this 2day. thanx
