hey had a few probs with car l8ly so i had it all code read etc came bk with like 5 faults so i changed the maf and now ive changed the lambda sensor runs alot better having changed the lambda and mpg is right back up 2 averageing above 35mpg which im happy with rather than 12mpg.
still the revs are slightly high like 1500rpm on idle and wen i change gear they seem to blip up when clutch is pressed so i can never get a smooth gear change without a slight jolt???
so ive put it back on the code reader it came up with 5 still so i erased them all unpluged went for a drive and tryed again. now there is NO codes which is a good thing but still driving pretty lumpy. could it still possibley the maf? i had to buy cheap as i have just been made redundant
i no u lot dont advise this but could this be the problem? also anything else i could check or do to get it running better? spark plugs, filter, throttle body clean etc etc??
thanx
