Author Topic: Do I need to change my injectors as well as nozzles?  (Read 897 times)
Offline MK3TDi1996
hello folks,
As i'm going to be replacing my injectors soon, i'm wondering is it worth buying just the nozzles (bosio) or is it best to replace the entire injector?
Thanks
« Last Edit: 28 June 2009, 13:09 by MK3TDi1996 »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Uprated diesel injector question
« Reply #1 on: 27 June 2009, 10:33 »
Send em off to be overhalled then change the nossle or fit new ones,  but be warned,  a new set of stoc injectors  for my TDi was £650...   So depends how your doing it,  if you are fitting them out of a diffrent vehical just stick the whole thing in, but still have them tested and cleaned, and rememeber you cannot mix the order they came out,  and fitting them to a diffrent engine is  a bit of a no no but usualy is ok.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline MK3TDi1996
« Reply #2 on: 27 June 2009, 13:07 »
What is involved in the overhauling? Forgive my ignorance but if the injectors are working then great, I can just replace the nozzles right?
Offline MK3TDi1996
Re: Do I need to change my injectors as well as nozzles?
« Reply #3 on: 28 June 2009, 13:09 »
So do I need to change the injectors as well as the nozzles?
Offline Rmachines
« Reply #4 on: 28 June 2009, 19:16 »
Personally i would do both,  overhalling them will clean them, test them and re-adjust,  otherwise its putting old parts back on and who knows how long they will last ?!
If you replace the whole thing with new parts obviously it would be fine.
