Author Topic: ABF vaccum leak  (Read 1053 times)
Offline Winso
ABF vaccum leak
« on: 26 June 2009, 19:23 »
The vac hose that comes off the inlet manifold in the pic below is leaking a bit. Hopefully I'll get a chance to sort it tomorrow...
2 things though.....
I remember reading somewhere that a vac hose on either the ABF or KR has to be a certain exact length and that you can't chop a bit off the end to fix a proplem like mine. Please tell me that's not this hose....
Also... where does this pipe go anyway? and what are the likely effects of it leaking a bit?
Thanks!
jamie16v
Re: ABF vaccum leak
« Reply #1 on: 26 June 2009, 19:55 »
this happened on mine and made it run like a sack of sh!t, i replaced it with 3mm internal diameter silicone stuff from ebay.. done the trick and looked the part..
« Last Edit: 26 June 2009, 19:57 by jamie16v »
Offline tweed
Re: ABF vaccum leak
« Reply #2 on: 26 June 2009, 20:30 »
Well if it's leaking it needs replacing, so why not chop a little bit off?
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: ABF vaccum leak
« Reply #3 on: 26 June 2009, 20:34 »
No it doesn't need to be an exact length but tbh its better to replace.....as said use some 3mm id, get it from ebay, i brought some from a company called zenna racing when i had my old valver.
This hose leads to the ecu and can cause idling/stalling issues if its faulty.
While your at it you might aswell replace all the other vac hoses around the engine as they will all start to be breaking down.
