Author Topic: Running Temperature  (Read 2396 times)
Offline Ashley
Running Temperature
« on: 25 June 2009, 22:21 »
Just a quick question for everyone to answer really   :tongue:
At what temperature does your car run?
Mines been sitting at 70, going up to 90 if running hot or in traffic for a long time, until recently it started sitting at 80/90 as standard. I've had the thermostat and new coolant and it sits at 80 as standard now
A friend told me MK3s run at 80/90 - is this right?
cheers
Offline jason2875
  • mk3 vr6
Re: Running Temperature
« Reply #1 on: 25 June 2009, 22:33 »
my mk3 vr6 runs at 70 never goes any higher no mater what speed or if in traffic mate
Offline Andy-H
« Reply #2 on: 25 June 2009, 22:46 »
Mine runs between 80/90 and has done this for the last year since I owned it   :wink:
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #3 on: 25 June 2009, 22:50 »
Mine sits bang on 90, never goes up or down when warm.
Offline Ashley
« Reply #4 on: 25 June 2009, 22:51 »
See this is quite interesting.. would be interesting to get a load of answers and find a trend  :undecided:
Offline chrisford_vw
« Reply #5 on: 25 June 2009, 22:57 »
Bang on the middle 90 in traffic and never seen it go any higher as it cools i goes down
Offline Paul86S2
« Reply #6 on: 26 June 2009, 00:06 »
Mine sits in the middle of the gauge and never moves, sat in traffic, going along slowly or flat out on the track.
Paul
Offline chilli_dub
« Reply #7 on: 26 June 2009, 08:10 »
Are we talking about the MFA oil temp or the coolant temp gauage on the dashboard? If were talking about the guage on the dash then mine sits bang on in the centre and never moves up or down!
« Last Edit: 26 June 2009, 10:34 by chilli_dub »
« Reply #8 on: 26 June 2009, 08:53 »
should run at 90degrees, if lower either stat is missing or stuck open. could also be a sensor/dash fault, what does the oil temp say on the mfa if you have one?
« Reply #9 on: 26 June 2009, 09:09 »
90degrees is around where mine used to run.
