Author Topic: door issues?  (Read 862 times)
Offline mani12354
door issues?
« on: 25 June 2009, 17:41 »
hi all i just wanted to know how the hell can i raise my doors because my car does not shut the doors properly
Offline spunkymonkey
  • Tepidly moist! That's what that is!
Re: door issues?
« Reply #1 on: 25 June 2009, 19:06 »
If they are too low just open them, grab them at the bottom and pull up sharply a few times.
Offline Vdubbster
Re: door issues?
« Reply #2 on: 25 June 2009, 21:15 »
Agree, try this at first
Re: door issues?
« Reply #3 on: 25 June 2009, 21:24 »
If the above does not work you may need new hinge pins.
Offline Grim_Reaper
  • warningz...i haz powaz
Re: door issues?
« Reply #4 on: 25 June 2009, 22:58 »
i doubt he needs new hinge pins, just remove your arch to get the the hinge bolts, loosen them (MAKE SURE THE DOOR IS SHUT!!!), lift the door up a little by the handle to where its meant to sit, and while your lifting it tighten how ever many bolts you can...its easier if you get someone to hold the door up or tighten the bolts for you
