Author Topic: height adjustment  (Read 1358 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
height adjustment
« on: 25 June 2009, 17:10 »
well im going to fit coilovers to my golf
never done it before
i want my car as low as possible, but want it to be able to get over speed bumps:)
so what height front and back am i looking at going for?  :smiley:
Offline Adam
Re: height adjustment
« Reply #1 on: 25 June 2009, 17:13 »
Depends on your speed bumps,  where I live the speed bumps can kill my car and mine ain't that low!
Down Hill From Here.
Offline tobybrennan
« Reply #2 on: 25 June 2009, 17:15 »
whats yours?
« Reply #3 on: 25 June 2009, 17:17 »
Set them just below half way, then drive the car for a few weeks and let it settle, then adjust as required.
Offline shepgti
« Reply #4 on: 25 June 2009, 17:17 »
go for around an 80 mm drop (about 3cm form the bottom of the thread on the coilies)
Offline tobybrennan
« Reply #5 on: 25 June 2009, 17:20 »
yeah yours looks about perfect for what i want shep
« Reply #6 on: 25 June 2009, 19:18 »
Worth remembering they will settle so you are better to set them higher 1st and then tweak the height a few weeks later.
Offline tobybrennan
« Reply #7 on: 25 June 2009, 19:57 »
okay wayne will do!
cheers
Offline Len
« Reply #8 on: 25 June 2009, 20:56 »
If you have loads of speed humps you will have to be sensible! Plus check new height at kerbs!
www.sas.org.uk
www.the-ace.org.uk
Offline ian24driver
« Reply #9 on: 26 June 2009, 06:25 »
 I slammed mine 70mm on some hotuning coilovers with some 17" TT alloys, its ok with speed humps aslong as you take it easy over them, does catch on the front slightly on full lock but nothing too bad, i can live with it cause it looks quality.
