Author Topic: Pipe size on exhausts  (Read 2076 times)
Offline funkyfive
« on: 24 June 2009, 07:17 »
Help needed again!!  :smiley:
I have just bought a magnex system off edition38 for £60 notes but its for a VR6 and I have a 8v.
Does anyone know if i need a reducer pipe or will it go straight on?
If i do need a reducer pipe what size is the standard exhaust pipe on a 8v?
Re: Pipe size on exhausts
« Reply #1 on: 24 June 2009, 07:57 »
You will need a reducer.
Offline funkyfive
« Reply #2 on: 24 June 2009, 08:28 »
Thanks do you know what size as there seems to be loads. I am just after the diameter of the standard piping on a 8v?
Offline funkyfive
« Reply #3 on: 24 June 2009, 20:17 »
Fitted the exhaust on today, no need for a reducer at all. the diameter is 55mm on the vr6, 8v and 16v.
Offline Adam
« Reply #4 on: 24 June 2009, 20:21 »
 :huh: The 8v should be smaller! 2" rather than 2.5" for the 16v and VR6 iirc
Down Hill From Here.
Offline funkyfive
« Reply #5 on: 24 June 2009, 21:27 »
Not on mine, it fitted on without the need to change the sleeve that goes onto the cat? I will take it off tomorrow and check again to be sure.
Offline funkyfive
« Reply #6 on: 28 June 2009, 13:31 »
I checked again and can defo confirm that the pipe size is 55mm on the 8v and no reducer was required for a magnex exhaust system product code XSVWG4/3
Offline Mikester
  • Civic Type R
« Reply #7 on: 28 June 2009, 16:11 »
think the 8v is 2 1/4 inch and the 16v/vr6 is 2.5 not sure though.
Offline reed5410
« Reply #8 on: 28 June 2009, 19:02 »
i fitted a powerflow off a 16 valve on my driver and it fitted no probs
Offline funkyfive
« Reply #9 on: 29 June 2009, 11:53 »
I checked with Kwik Fit and they confirmed the diameter was the same on the 8v, 16v and VR6.
