Author Topic: ABS light on after disconnecting some wires near ignition????  (Read 866 times)
Offline whit
after disconnecting a couple of connectors near the ignition the ABS light is now on all the time???
how can i get it to go off after starting like it did before i disconnecting these wires?
Offline chilli_dub
Firstly which wires have you disconnected near the ignition? Chances are youve loosened one of the ABS signal wires. Trace the ABS wires from the rear of the ABS light cover right back to the fuseboard, make sure there are no breaks etc.
eiprahs
check fuse too in case you shorted a wire in the process
Offline whit
it seems to be the connector to the ignition switch that affects the ABS light
why would it now stay on all the time after disconnecting the ignition switch???
if it's a fuse any idea which one it is??
eiprahs
abs fuse try
