Author Topic: VR6 fuel pump replacement..  (Read 2840 times)
Offline kranto
« on: 23 June 2009, 17:47 »
Hi!
Some days ago we tried to start my Golf III VR6, but it wouldn't.
We found out that the fuel pump doesn't start and we want to replace it.
The local junkyard said that the fuel pressure is different on a VR6 than for example a Golf GL, and we couldn't replace the original one with an ordinary Golf GL fuel pump.
Is this right? Do we have to get an original VR6 fuel pump?
What is the pressure sent out on the original VR6 fuel pump?
The part no. is: 1 HO 906091 C (or 1 H0 906091 C)
Thanks for all replies:D
« Last Edit: 23 June 2009, 17:49 by kranto »
Re: VR6 fuel pump replacement..
« Reply #1 on: 23 June 2009, 19:09 »
Yes vr6 is higher pressure.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 23 June 2009, 21:08 »
Same as the 16v no?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #3 on: 23 June 2009, 23:52 »
Same as the 16v no?
Yes I think it is.
Offline kranto
« Reply #4 on: 24 June 2009, 14:50 »
So I cant replace the original with a golf GL pump, but with a 16v pump?
(Thanks for the answers :wink: )
Offline LazyLunatic
  • MK3 20VT Project
« Reply #5 on: 24 June 2009, 20:11 »
16v and vr6 are the same pump. although they all look the same....
Offline Len
« Reply #6 on: 24 June 2009, 20:42 »
Pain in the ass to change as well>
I did a thread about it when I did mine so do a search and find that! :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline Rmachines
« Reply #7 on: 24 June 2009, 22:01 »
its one of those jobs thats hard the first time and really easy the seccond  :grin:
« Reply #8 on: 25 June 2009, 11:00 »
VR6 & 16v pump is not the same. 2.0 8v/16v pump is rated to 3 bar, VR6 rated to 4bar.
