Author Topic: HELP!!! please i just brokedown....  (Read 3025 times)
Offline Dave_GTI16v
  • 'Guns N' Roses'
« on: 20 August 2004, 20:17 »
Hi all, i just got towed home, well i was driving, everything was normal, put ?30 of optimax, went to kfc, and switched the engine off, started it up about 15 minutes later, got on the main road, going about 40 miles an hour, changed into 4th gear, put my foot down and there was no acceleration, there was a slight low noise when i pressed the accelerator, i changed into 3rd, same thing happened, then went into second same thing happened, it was just gettin slower, so i pulled over and it cut out. tried starting it up again and it wouldnt kick in, it was trying though, i checked the engine and, oil water etc, seems normal, my bro said it could be something to do with the fuel pump, but if any of u have any ideas please reply, thanks!
MK3 GTI 16V '95'
''its better to regret something u did, than something u didnt do''
Offline Dizzie
  • Make friends with your fast
Re: HELP!!! please i just brokedown....
« Reply #1 on: 20 August 2004, 20:19 »
checked the fuel pump relay?
Mk4 Golf 150PD
Fielder5757
« Reply #2 on: 20 August 2004, 20:20 »
do you normally use optimax?
Offline Dave_GTI16v
  • 'Guns N' Roses'
« Reply #3 on: 20 August 2004, 20:22 »
thanks, for the quick replies, ill check the relays, and yes ive always used optimax
MK3 GTI 16V '95'
Offline Dizzie
« Reply #4 on: 20 August 2004, 20:30 »
the ECU should automatically adjust the timing to whatever fuel you decide to use.
Mk4 Golf 150PD
Offline AdamB
  • The Perfect Storm
« Reply #5 on: 20 August 2004, 20:38 »
If it just died and ran to a halt, check your dizzie cap, or rotor arm. Bit of a weak spot, and if it goes, it will seem the engine is running as the car slows to a stop.
I don't own this anymore - I just can't be arsed to change the picture
Offline Dave_GTI16v
  • 'Guns N' Roses'
« Reply #6 on: 21 August 2004, 10:17 »
hey again, took it the garage today and i think its pretty much what AdamB said, so thanks for ya help, its costin me ?75 fitted. sh!t happens.
MK3 GTI 16V '95'
Fielder5757
« Reply #7 on: 21 August 2004, 10:20 »
?75 is a sweet repare bill, Wait till you slam the car sideways into a curb and rip appart your steering, ?500 repair bill and a ?700 set of alloys later im back in buisness  :o
Offline Dave_GTI16v
  • 'Guns N' Roses'
« Reply #8 on: 21 August 2004, 10:34 »
holy sh!t, when u put it like that, it aint so bad  :o
MK3 GTI 16V '95'
Offline AdamB
  • The Perfect Storm
« Reply #9 on: 21 August 2004, 12:10 »
Glad I could help, but if it really was something as simple as that, then I think ?75 was a bit steep. The parts are less then ?15, and its only a 5 minute job to change them over. Did they have to pick the car up? not a bad price if that was the case.
