Author Topic: Poss alternator/immobiliser prob.  (Read 1496 times)
Offline vwnutt
« on: 20 August 2004, 13:59 »
Hi
VW GOLF GTI 16V 1990 OAKGREEN.
Problems started last week.
Turned on the ignition and no battery light.car started ok.
 battery light flickered on but went out when revved.(thought was loose belt).....got in car yesterday.....no battery light..started ok.....stopped at garage........turned key...........nothing!..as though the battery was flat.
jump started.....cut out on way home.......tried to restart......nothin...tested  battery 11.66v.
jump sarted..........left running for 1- 1 1/2 hours.........alternator charging at 14.3 v.........turned off.......battery voltage...13v.
disconnected battery..........left overnight.......tested this morning and battery voltage was 12.4v.
turned on ignition and all lights there......started ok.
Left car at home and will test if battery has dropped when i get back from work.
any ideas?
car has an immobiliser.
Offline Dizzie
  • Make friends with your fast
Re: Poss alternator/immobiliser prob.
« Reply #1 on: 20 August 2004, 20:24 »
loose alternator leads.
Mk4 Golf 150PD
Offline vwnutt
« Reply #2 on: 01 September 2004, 08:51 »
all sorted..........cleaned the brushes.
bobs your uncle.
