Author Topic: Newbie help with gearbox  (Read 1207 times)
Offline wessex
« on: 22 June 2009, 23:14 »
Hi i was just woundering what gearboxs fit a 8v mk3 as my one has striped a tooth .ARE the deisel boxs the same and is my one a 020 . also is there anyway of adjusting the fuel mixture on my car as i have been told it is running rich.And sorry to go on any good cheap performance mods to start me of with  :smiley:thanks and hello to all
Offline Adam
Re: Newbie help with gearbox
« Reply #1 on: 22 June 2009, 23:18 »
The 020 and the 02a will fit aswell.
Yea they are all the same as long as its a 5 speed box.
More info
http://boneybradley.webs.com/thegearboxes.htm
Down Hill From Here.
Offline wessex
« Reply #2 on: 23 June 2009, 16:14 »
Ok thanks 4 the help and link :grin:
« Reply #3 on: 23 June 2009, 16:38 »
the MK2 16v and MK3 GTI 8v box has a larger input shaft, so if you get a std 8v box you need to change the friction disc.
02a isnt a direct drop in replacement, you also need the gearstick & cables, plus either hydro clutch pedal box or SEAT ABF hydro->cable conversion setup
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 23 June 2009, 21:05 »
I have an 8V GTI Box for sale?
Dont forget the TDI, 16v and VR6 are cable change and hydraluc clutch so some conversion needs doing there.
I can see a diesel box being a bit crap to drive with on a petrol though... I mean the ratios are miles out!  I dont have to take my TDI above 2000 RPM and will get good power and speed,  i think for an 8v its a bit long, would loose that pull.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline VWstevo
  • I feel The Need or Speed
« Reply #5 on: 24 June 2009, 00:52 »
Hi mate
How much do you want for the GTI 8v gear box, mine is very noisey in reverse, so think I need a new one. Cheers. Steve.
