Author Topic: fuel tank sender  (Read 919 times)
Offline mikemk4gti
fuel tank sender
« on: 22 June 2009, 20:12 »
 Finally got round to finding out why my car runs out of fuel even when showing 1/4 tank.
Let it run down today and took the top of the tank of to confirm it was empty and it was although gauge said otherwise, took to pump/sender unit out and operated the float but even when at the bottom the tank shows 1/4. If I disconnect the 2 sender wires and join them together the gauge reads zero as it should. So, I need a new sender (unless anyone thinks there may be a different fault) wheres the best (cheapest) place to get one? VW want about £53 for it. :sad:
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline mikemk4gti
Re: fuel tank sender
« Reply #1 on: 28 June 2009, 18:11 »
anyone?
Offline mikemk4gti
« Reply #3 on: 28 June 2009, 19:53 »
it looks similar but not the same so not sure if it will work properly?
