Author Topic: gearbox identity!  (Read 1989 times)
Offline andc1
gearbox identity!
« on: 22 June 2009, 18:40 »
hi all, well i got a 16valver in the mk1 as i bought it already fitted, im having trouble with the gear selector so im thinking of getting a new repair kit but im not sure what gearbox is in mine, anyway to tell what gearbox i have?
Re: gearbox identity!
« Reply #1 on: 23 June 2009, 10:36 »
have a look at the top, if it has a load oif rods on its an 020 rod shift, if it has 2 cables its 02a cable shaft. unlikelyt to be a cable shifter if its a boggo valver though.  If its a rod shift get yourself a bog std MK1 GTI rebuild kit, they're all the same.  Though I guess it could have MK2 linkages bodged in? got any pics?
Offline andc1
« Reply #2 on: 23 June 2009, 17:40 »
these are about the best i can get
« Reply #3 on: 25 June 2009, 11:12 »
thats a rod shift alright, and it has the proper MK1 linkage. I can see the early MFA multi pin plug on it so chances are its the original MK1 gearbox.  You need a bog std MK1 GTI bush kit :)
Offline andc1
« Reply #4 on: 25 June 2009, 18:44 »
cheers for that, is this gearbox ok on a 16 valver engine? its not as rapd as i thought when i got it
« Reply #5 on: 26 June 2009, 08:47 »
depends what code it is and what you want out of it, balls out accelleration, economy or something in between!  the gearbox code is on a flat part of the bellhousing at the bottom, along with a date code giving the date it was made.
