Author Topic: Mk3 GTi cutting out once hot  (Read 1175 times)
Offline gti sa
  • Power from the GODS
« on: 22 June 2009, 16:51 »
Of recent I have been experiencing cutting off once the engine gets hot.  I will be driving along and all of a sudden the rev will drop however receover very quickly.  The car does not switch off though.  This only happens when the engine is hot.  Not sure if it is the Coil, ECU relay or Fuel pump relay.  I decided one day to turn off my radio and listen out for any suspicious noises.  When the engine decided to dip I did hear a relay click.  Now I am not sure if this is because the engine has almost switched off or there is actually something wrong with a relay.
Please help with any ideas'....
Offline robz
Re: Mk3 GTi cutting out once hot
« Reply #1 on: 22 June 2009, 17:20 »
check the search mate, usuall/common problem...
im having it atm!! lol
if you here relays clicking then thwy should be fine!!
have a search thn post again if your stuck ;)
Offline gti sa
« Reply #2 on: 22 June 2009, 18:47 »
nothing coming up on the search mate....
Offline gti sa
« Reply #3 on: 22 June 2009, 18:51 »
found it.  searching the wrong place.  Thanks for this.  will take a look at a few of these things.
Offline axewielder
  • 95 dragon 8v
« Reply #4 on: 23 June 2009, 21:18 »
will be crank sensor, mine was litterallyy the same, only when hot :sick:
all fixed with a 5 quid one from scrappy
Offline VWstevo
  • I feel The Need or Speed
« Reply #5 on: 24 June 2009, 00:38 »
I had the same problem with mine and I just changed the Distributor £87 from GSF. Good as new. Or by the way you have to take your old Dizzy in with you as part exchange. Hope this helps. Steve.
Offline axewielder
  • 95 dragon 8v
« Reply #6 on: 24 June 2009, 19:35 »
you can check if its the cam sensor on the dizzy by leaving it unpluged+seeing if it still cuts out, engine shoulld run alright without it for testing, no point changing things without testing first
