Author Topic: engine fan staying on  (Read 1921 times)
Offline andc1
« on: 22 June 2009, 16:47 »
hi all, been out today and warmed the car up nicely and everything was good, fan cut in when getting hot, but now the  fan wont turn off!!! i have to pull the wire out from the bottom of the rad for it to stop! any ideas? temp sensor? if so is it the plug on the bottom of the rad where i have took the 2 wires off?
Re: engine fan staying on
« Reply #1 on: 22 June 2009, 17:09 »
fact it stops when you unplug it from the sensor means its the sensor at fault :)
the fan should run on till gauge drops to just below 1/2ish, which it might struggle to do if idling on a hot day.
« Last Edit: 22 June 2009, 17:12 by rubjonny »
Offline andc1
« Reply #2 on: 22 June 2009, 17:34 »
ok so it will be the sensor on the bottom of the rad then?
« Reply #3 on: 22 June 2009, 17:55 »
it sounds liek it yes, as long as you're leaving it long enough for the fan to do its job :)
Offline andc1
« Reply #4 on: 22 June 2009, 18:35 »
yea i went back out in it an hour later and the thing was still going round and nearly a flat battery!!
« Reply #5 on: 23 June 2009, 10:37 »
yep thats donald ducked!
Offline andc1
« Reply #6 on: 23 June 2009, 17:43 »
cheers all
