Author Topic: hall sender  (Read 708 times)
Offline chezney55
hall sender
« on: 21 June 2009, 19:55 »
changed hall sender and distributer on my 8v gti still cutting out and hesitating!!!!!!!! any help would be great
Offline VWstevo
  • I feel The Need or Speed
Re: hall sender
« Reply #1 on: 24 June 2009, 01:07 »
Hi Mate, had the same problem on mine. I've just changed the Dizzy a few days ago. Not had any problems as yet. Touch wood LOL. Before changing the Dizzy I changed the coil as the ignition moduel can get hot and when you try to start your car it just turns over and won't start for ages until it's cooled down, £47 from GSF 5 mins to fit it. I've also changed the relay switch for the petrol pump, I changed the petrol pump also, easy to fit also, carn't remeber the cost £60 i think. New HT leads also could be a bad earth. Hope this helps buddy. Steve.
« Last Edit: 24 June 2009, 01:11 by VWstevo »
Offline chezney55
Re: hall sender
« Reply #2 on: 24 June 2009, 16:30 »
will try that mate cheers
