Author Topic: oil leak  (Read 681 times)
Offline vw-8v
oil leak
« on: 21 June 2009, 14:18 »
i read the links and think as suggested it comming from the oil sensor, whow do i go about sorting it????
drain oil????? will do prob anyway as needs new filter.
if fright then wot?????
do i need any washers like sump????
cheers
Offline Paul86S2
Re: oil leak
« Reply #1 on: 21 June 2009, 21:23 »
You should be able to change it without draining the oil. If it needs a washer it will come with one.
Good practice to put a new sump plug washer o everytime you remove the sump plug.
Paul
Offline vw-8v
Re: oil leak
« Reply #2 on: 21 June 2009, 21:30 »
cheers m8 will look into cost of new one, unless it just a take out and renew the seal if there is one which just time and a couple of pennies.
thanks agian
