Author Topic: Hard to handle  (Read 1882 times)
Offline jon007
Hard to handle
« on: 19 August 2004, 20:24 »
I have a Mk 3 16v. What are the options to make it fun to drive? If I push too hard it slides and otherwise it's downright dull. Previous car was a 205 gti which was on rails. How can I make the golf feel at least halfway to the pug? Max about ?400 - but the less the better!
Offline Dizzie
  • Make friends with your fast
Re: Hard to handle
« Reply #1 on: 20 August 2004, 20:29 »
what tyres and suspension are you running?
Mk4 Golf 150PD
Blue MK2
Re: Hard to handle
« Reply #2 on: 20 August 2004, 20:51 »
coilovers
Offline AdamB
  • The Perfect Storm
Re: Hard to handle
« Reply #3 on: 20 August 2004, 20:55 »
Blue's right - the suspension is lacking on a mk3, upgrade it to something decent, not neccassarily coilovers, but a decent set of shocks should come in under budget and provide you with a better handling car. I hate to say it, but you will be hard pushed to get a mk3 handling like a Pug GTI for under ?400 as the one thing the pugs did have going for them was their handling.
I don't own this anymore - I just can't be arsed to change the picture
Blue MK2
Re: Hard to handle
« Reply #4 on: 20 August 2004, 20:59 »
Blue's right
:P
for 375 quid you can get Supersport goldline coilovers. job done right?
« Last Edit: 20 August 2004, 21:02 by Blue MK2 »
Offline Dizzie
Re: Hard to handle
« Reply #5 on: 21 August 2004, 00:46 »
I'd say tyres were the first thing you should sort out. running sh!te tyres is going to effect the handling a lot. since moving to branded tyres my grip has improved loads.
Personally I wouldn't bother with coilovers. Yes they give you unlimited height adjustment, but unless you pay big money for a damping adjustable set there's not much gain over a decent shock/spring combo like Koni and eibach. If you can't fit them youself then you'll need to account for labour costs as changing all 4 shocks and having them tracked, etc will take several hours. It took the bloke that changed the springs on the back of mine at least an hour and he was working like a machine on it for a set rate.
Mk4 Golf 150PD
Offline jon007
Re: Hard to handle
« Reply #6 on: 25 August 2004, 20:24 »
Avon ZV1's. Not good but not THAT bad! Tread's decent and they grip ok in the dry but very slippery when wet (not wishing to quote bon jovi!!)
