Author Topic: VR6 Overheat but had a new head gasket n thermostat  (Read 2087 times)
Offline samy_1800_turbo
my mates vr6 keeps over heating he removed the thermostat completely it still did it and now hes replaced the head gasket n it keeps bubbling up the water. any advice i have not looked at this yet but will be soon so need so help. i herd the vr6 are a pain to bleed.
Offline AudiA8Quattro
Re: VR6 Overheat but had a new head gasket n thermostat
« Reply #1 on: 20 June 2009, 23:20 »
Failed water pump?
« Reply #2 on: 21 June 2009, 14:19 »
how do i check this. does this mean the rad want keep hot n no hot air in the heater as its not pumping water round
Offline Grim_Reaper
  • warningz...i haz powaz
« Reply #3 on: 21 June 2009, 14:44 »
are you sure that there isnt an air leak and its been bled properly???
Offline paultownsend
« Reply #4 on: 21 June 2009, 15:00 »
dont the vr's have 2 pumps?
Offline golf newbie
« Reply #5 on: 21 June 2009, 16:56 »
Quote
yep a electric one.
would look into that..
« Reply #6 on: 21 June 2009, 18:28 »
The electric pump only runs when the engine is switched off, to prevent hot spots in the engine.
« Reply #7 on: 21 June 2009, 18:43 »
so the eletric one should cause a problem then when the engines running
« Reply #8 on: 21 June 2009, 18:45 »
No, the electric pump only runs when you stop the engine.
Check the main pump.
« Reply #9 on: 21 June 2009, 19:23 »
how do i check if its working surly if the rads geting hot it n i get hot air i guess its working is this correct
