Author Topic: Working Out Offsets - HELP  (Read 1588 times)
Offline Benji_DuB
« on: 20 June 2009, 13:46 »
Im buying a new set of alloys for my mk3 but need to find out the offset of my wheels which i have on now, so i can work out how my new wheels will sit/what i will need to do with the arches (pulling and flaring) when i drop it. I Plan on gettin 7.5" Front and 9" back, but because i dont know my offsets of my wheels at the mo i dont know the what correct offset are needed for the new ones. The Alloys on my car now are 8 inches wide front and back as the tires are 205, but i havnt got a clue on how to measure my offset.
I know that the offset is the difference between the hub and the alloy itself, but how do i measure it when the wheels are on the car??, finding it a bit confusing and stressful.
Offline avengedslayer
Re: Working Out Offsets - HELP
« Reply #1 on: 20 June 2009, 14:00 »
is the offset stamped on the inside of the wheel? it could say ET35 or summet?
Offline Benji_DuB
« Reply #2 on: 20 June 2009, 16:51 »
yesss man sorted et35, took the wheel off and had a gander was stamped behind the spokes sweeettt.
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #3 on: 20 June 2009, 17:20 »
If you get 9j on the rears you need something like ET25 minimum or it will hit the shocks. Most 9j rims come ET15.
Offline Benji_DuB
« Reply #4 on: 21 June 2009, 13:29 »
if its 9" is there more alloy towards the shocks?? and then the offset dertermines the distance of that from the shock?? is there a way of measuring that?
Offline shepgti
« Reply #5 on: 21 June 2009, 14:53 »
the distance towards the shock isnt the issue, the lower the et (offset) the more the wheels will stick out the arches
Offline Benji_DuB
« Reply #6 on: 21 June 2009, 17:55 »
Planning on having the backs sitting on 205/40 so a slight stretch to allow for the arches, also getting them pulled and may get a flare if its needed.
Decided to get 7.5" at front with et20 sitting on 195/45, and back 9" at et25 with 204/40. Sound reasonable? (16" Rims)
Ive made measurements and itl stick out and extra inch at the back basically, plus a cm for the offset, which is just right. The front will push out an extra 3 mils so no change in that which hopefully means it will fit nicely under the arches.
The wheels come from the manufacturer with the highest offset of 25 the lowest in 15 but i dont want it to stick out too much, adds more works for the arches.
« Reply #7 on: 21 June 2009, 19:00 »
It is on a 9j rim.
« Reply #8 on: 21 June 2009, 19:09 »
Et25 should be ok, et15 will need a lot more work to the arches.
« Reply #9 on: 21 June 2009, 22:08 »
Id go for et25 then space slightly to suit if need be.
