Author Topic: Howto remove brake fluid reservoir?  (Read 2142 times)
Offline Mr Blue
Re: Howto remove brake fluid reservoir?
« Reply #10 on: 20 June 2009, 09:57 »
You wont need a spanner to keep the valve open if that what your thinking. It works with a spring yes.
you can use a cable tie to keep it in the open position
Offline bomp
« Reply #11 on: 20 June 2009, 11:51 »
Bomp...that master cylinder looks mint!
Cheers Blue  :smiley:  I first painted 3 layers of black smooth Hammerite on it, but I didn't like the brush lines, so I feathered out most of the brush lines with P400 wet & dry, then bought a spray on black smooth Hammerite, and put about 2 layers on (15 mins between each) and let it bake in the sun for a couple of days to harden, because it takes days to go off. Then I did a final cut back with P1000 and sprayed a final layer.
I had to paint it, because every time I opened my bonnet, the first thing that caught my eye was the big round pile of rust that is supposed to help me stop.  :laugh:
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline Dolly
« Reply #12 on: 21 June 2009, 13:03 »
if your just removing then refitting the resoviour you wont need to bleed it, as long as the brake pedal isnt pressed during the time its off/empty.
this is because its the highest point on the system innit.
