Author Topic: what rong with my car? pic in side  (Read 1047 times)
Offline louis_23
« on: 19 June 2009, 16:31 »
hi guy's im usless when it comes to the mechjanical side of things, i cleaned my engine bay not to long ago and now its nice a clean i have noticed  what looks like a slow leak from area in pic below, is this bad? whats causing it where is it comming from?
Re: what rong with my car? pic in side
« Reply #1 on: 19 June 2009, 16:34 »
I'd say its that coolant flange, oring gone in it prob, is a common fault. Id do the one on the side as well
Offline louis_23
« Reply #2 on: 19 June 2009, 16:48 »
will this cost alot and also my car wouldn't start dis morning would that be down to this aswell?
« Reply #3 on: 19 June 2009, 17:18 »
nah they're dirt cheap, easy fix too! non-start could be down to the ecu temp sensor, its the 4 pin black thing in the flange there, unrelated to the leak I'd have thought though. all that white crud round the sparky lead might be a clue, best whip it off and give that area a clean, and check the lead/plug for damage.
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #4 on: 19 June 2009, 17:33 »
The flanges are about £15 for the pair and you will need some vw antifreeze. Easy job. The temp sensor would be my first port of call for the starting too.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 20 June 2009, 12:49 »
What the monkey said ^^^
