Author Topic: MK2 GTI Timing belt cover  (Read 2004 times)
Offline oldmiller8
« on: 18 June 2009, 22:59 »
I have a MK2 GTi with an early k jettronic engine with the code ev.
Trouble is, I've lost my top timing belt cover and was wondering if any 8v cover would fit.
« Last Edit: 18 June 2009, 23:16 by oldmiller8 »
Offline Diamond Hell
  • Opinions я Us
Re: MK2 GTI Timing belt cover
« Reply #1 on: 19 June 2009, 00:08 »
I suspect you'll need a metal top to fit to your metal lower cover.  Any 1.8 cover should do.
Offline Ben Lessani
« Reply #2 on: 21 June 2009, 10:44 »
My EV has never had a top cover (last owner must have lost it). But at least I can see the wear on the belt whenever I jump into the bonnet.
VeeDubGTI16v
« Reply #3 on: 21 June 2009, 10:52 »
you can see when a stone gets jammed under the belt as well  :grin:
Offline Ben Lessani
« Reply #4 on: 21 June 2009, 16:10 »
I think if stones are rolling around the top of my engine bay, I have much bigger troubles
Offline sparkplug
« Reply #5 on: 21 June 2009, 19:01 »
took mine off an binned it .
1986 GTI atlas grey
Offline Khare
  • The bear that khares
« Reply #6 on: 21 June 2009, 19:12 »
I didn't run ANY covers on my old mk2, never had a problem and I did plenty of trips with gravel on the ground.
Offline AudiA8Quattro
« Reply #7 on: 21 June 2009, 19:23 »
I would run the car with the covers on. Its how it was meant from factory.
Whether people actually want to is down to personal preference.
Offline oldmiller8
« Reply #8 on: 21 June 2009, 21:14 »
Agreed! Covers are there to keep stuff out. And it's only the top plastic cover I need now as I've found the bottom cover.
Offline wil0
« Reply #9 on: 21 June 2009, 23:57 »
£13 from vw, i just bought one, and all the fitting holes are in the wrong place. i would run one, just so you dont trap your fingers in it, or drop some sh!t in there. its up to you tho, its not essential.
3Door Oak Green 91 MK2 16v GTi
