Golf mk3
hardmonkeys
8v gti
Topic: 8v gti (Read 1116 times)
chezney55
GTI forum regular
8v gti
18 June 2009, 21:14 »
g40 hall sender could this be the reason my car is cutting out and hesitating?? any help would be great???
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Re: 8v gti
19 June 2009, 00:07 »
yep and its common too (also check the wiring to it as this breaks up with age!) what code has vag-com showed up??
chezney55
GTI forum regular
Re: 8v gti
19 June 2009, 17:13 »
thats all it said mate is it the one that is connected to the distributer??
Last Edit: 19 June 2009, 17:19 by chezney55
axewielder
95 dragon 8v
Re: 8v gti
20 June 2009, 00:12 »
vag com said??
VW BUSH
Guest
Re: 8v gti
20 June 2009, 02:09 »
Quote from: axewielder on 20 June 2009, 00:12
vag com said??
NO
axewielder
95 dragon 8v
Re: 8v gti
20 June 2009, 12:32 »
Quote from: chezney55 on 19 June 2009, 17:13
that's all what said then??
boneybradley
Forum Supporter
Back in a Mk3...
Re: 8v gti
Reply #6 on:
20 June 2009, 12:54 »
yes the sender is on the side of the dizzy... but i would recomend a vag-com scan first as the hall sender is only 1 of several common mk3 issues
but if its defo the hall sender replace that and the wiring (it will show the same fault code)
chezney55
GTI forum regular
Re: 8v gti
Reply #7 on:
20 June 2009, 13:47 »
the computer at v dub. thats all it brought up. its geting changed 2day so will find out.
Golf mk3
hardmonkeys
8v gti
