Author Topic: Leather repair?  (Read 1878 times)
neo66
Leather repair?
« on: 18 June 2009, 20:35 »
I have a slight tear about 3cm long in the rear headrest, barely see it but I know its there!
Any method to which I can smooth it over. used Gliptone but thats only leather softner!
Thanks.
Offline rhoddy
Re: Leather repair?
« Reply #1 on: 26 July 2009, 22:45 »
hiya , gliptone have other products for torn leather ie, flexible gauze which will be glued behind the tear in the leather to bond the tear together, the glue is also strong and heat resistent, then you would apply the leather filler (or liquid filler) on the surface and smooth off and dry with hairdryer and if still noticeable you can re-grain the filler so this matches the leather then gliptone can supply you with the leather pigment (colour) to touch in the repair.
hope this helps.  :smiley:
